Old 11-18-2008, 05:03 PM   #1
bjs
ceramic tile to wood floor threshold
We're installing ceramic tile in our small bathroom, but are unsure how to deal with the threshold between the bathroom and hallway.
  1. Does the tile wrap into the door jamb?
  2. We removed the sloping wood piece that transitioned from the hallway to the old linoleum and it appears that the tile will be level with the wood flooring...do we need a threshold, or just a grout line?
  3. The tile is visible coming under the door into the hallway...should it be the other way around...see the wood floor from inside the bathroom? Maybe this is what warrants some kind of threshold??
Any suggestions will be appreciated...I don't seem to be smart enough to attach pictures!
bjs is offline   Reply With Quote
Old 11-18-2008, 05:52 PM   #2
Tileguy
Bud Cline's Avatar
Typically when floor coverings transition they do so under the center of the door. They are not to be seen extending under a door. You could achieve this by installing a new transition piece.
Old 11-18-2008, 06:10 PM   #3
bjs
Good to know--thanks!
Here is another question:
The baseboards have been removed. Should the tile be cut flush with the existing drywall, then covered with the new baseboards, or should the baseboards be installed (or leave room for them) so the tile butts up to them, instead of under them?
Old 11-18-2008, 06:30 PM   #4
Tileguy
Bud Cline's Avatar
The tile should be cut 1/4" short of the wall to provide a gap for expansion. The baseboards then cover this gap. Do not grout against the wall, leave the gap open and hide it with the base.
Old 11-18-2008, 06:50 PM   #5
bjs
The baseboards will cover it by sitting on top of the tile, or slipping down between the tile and the wall...I guess I could go measure my baseboard!
You've saved us from some little mistakes that would have made a big difference, thank you!
Old 11-18-2008, 07:12 PM   #6
Have a similar situation at hand, this tread came very handy. Tnx for the info.
Last edited by AtlanticWBConst.; 12-03-2008 at 10:46 AM. Reason: Site Rules Violation: Adertising Links Removed From Signature
seanJohn is offline   Reply With Quote
Old 11-19-2008, 10:26 AM   #7
Tileguy
Bud Cline's Avatar
Is that a question???
The baseboard sits on top of the tile and covers the gap. Your baseboard should be wider/thicker than 1/4" and should easily cover the gap.
Old 11-19-2008, 03:24 PM   #8
bjs
OOPS! Yes, that was a question...but it was also me realizing I could answer it myself.
Ok, one last question...hopefully.
First, do a dry run with all of the tile, cut everything to fit, etc.
Then...thin set everything from rear to door...OR thin set everything except the edges, wait until dry, then go back to set the remaining pieces???
Thanks, again!
Old 11-19-2008, 04:07 PM   #9
Tileguy
Bud Cline's Avatar
If THAT is what you are comfortable with then go for it but I wouldn't. I would establish the layout using the grid system of chalk lines then start deep in the room and install every tile as I backed my way out. That way it's done. You can cut as you go and unexpected changes in placement won't screw things up.
Old 11-19-2008, 06:52 PM   #10
if this is your first tile job i would plan the layout on paper, then measure the tiles you need to cut then cut them all making sure you have enough spares just in case. then mix the adhesive and lay the tile.
mattedfred is offline   Reply With Quote
Old 11-19-2008, 07:33 PM   #11
Tileguy
JazMan's Avatar
I don't know why people want to dry lay AND cut tiles before hand, then go back and hope it all works out the same again. Why would you want to lay it twice? It's a good way to turn a one day project into two days or longer?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 11-19-2008, 07:57 PM   #12
bjs
Okay then...we'll be getting started on Saturday. If I can figure out how to attach photos, I will.
Thanks for the info and the confidence to "go for it!"
Old 11-19-2008, 08:14 PM   #13
Floorwizard's Avatar
Just curious....what exactly expands?
Floorwizard is offline   Reply With Quote
Old 11-19-2008, 10:54 PM   #14
Tileguy
Bud Cline's Avatar
EVERYTHING expands!
Old 11-20-2008, 12:17 PM   #15
I was under the understanding that tile will stay put.
Any expansion from the product or subtrate would crack the tile or at least crack the grout.
I can see Ceramic expanding if it was frozen...but not from humidity......
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 08:46 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
