Ceramic Tile Vs Glueless Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2007, 02:12 AM   #1
Ceramic tile vs Glueless Laminate
When all is said and done.. Which product is less expensive for the DIY guy to install?
The house was built in 2004, 3/4" t&g plywood under the existing carpet. Adding this incase special padding or whatever is needed under either product. I assume ceramic tile can be installed right over the plywood but i really have no idea.
Thanks in advance
39centstamp is offline   Reply With Quote
Old 06-05-2007, 02:21 AM   #2
Floorwizard's Avatar
laminate will be overall more affordable and easier to install.
Less materials needed for install on lam. Ceramic may be able to be installed over ply only if the total thickness is 1 1/8 or 1 1/4 of an inch. Then you will still need a recommended membrane. Plus the tile, thinset, grout and the fact it will require a tile cutter.
Floorwizard is offline   Reply With Quote
Old 06-05-2007, 01:46 PM   #3
Thanks. I was leaning towards the laminate because it looks like less for me to screw up.
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
