Ceramic Tile Transition To External Threshold - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 08:22 AM   #1
JFH
Ceramic Tile Transition to External Threshold
Can someone offer ideas, please? I am installing a ceramic floor over an existing floor separated by Ditra. The floor extends to my back door. The new ceramic will raise the height by 3/8 or so, and I'm trying to figure out how to transition this height difference when I arrive at the rear door threshold. Any ideas, anyone?
Thx much
JFH is offline   Reply With Quote
Old 04-21-2011, 06:04 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How about a picture?
Is there actually a threshold there now? If so why is this a problem?
Not following.........
XXX
Old 04-21-2011, 07:39 PM   #3
JFH
The existing threshold in a half round type frost king. If I leave that in place, by the time I lay the Ditra and then the ceramic tile, the height is higher than the threshold.
Old 04-21-2011, 07:44 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK gotcha!
Now...is the threshold removable? AND, is it taller than the tile will be at some point?
I'm asking because if it is removable you can determine where it would meet the top of the tile and have it cut at that elevation. If it is an aluminum threshold once it is cut and re-installed it can be filled with foam in the underside to keep it firm and the joint where it meets the tile can be caulked.
If it is a wood threshold, it's no big deal.
The key here is "removable".
XXX
Old 04-21-2011, 07:45 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A picture would be really good.
XXX
Old 04-21-2011, 07:52 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I guess I should ask if this is an interior door with a threshold (for some reason) or an exterior door?
XXX
Old 04-21-2011, 08:06 PM   #7
JFH
It is an exterior, back door.
Old 04-21-2011, 08:09 PM   #8
JFH
OK gotcha!
Yes, it is removable, but it is below the level of the tile by a good 3/8 inch. In fact, I'll need to trim the bottom of the door as well.
Old 04-21-2011, 08:09 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sometimes the entire door unit can also be raised assuming the threshold is attached to the unit.
Raising a door isn't always a big deal.
Something to investigate and think about.
XXX
Old 04-21-2011, 08:17 PM   #10
JFH
That's not an option, Bud.
Old 04-21-2011, 09:55 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay. Why not?
XXX
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-23-2011 11:04 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
