Ceramic Tile Stains - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 03:10 PM   #1
Ceramic tile stains
Have newer home, ceramic tile in bathroom, appears that some contractor left drops of dark wood stain on a few tiles, tried different things to remove it, tiles are a light brown and stain is black in color.
bothbnp2 is offline   Reply With Quote
Old 05-12-2010, 03:56 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you sure this is ceramic tile and not a stone tile?
Try a little paint thinner or lacquer thinner on a Q-Tip and see if you can transfer any of the offending color to the Q-Tip.
If so...then make a poultice or buy a poultice and apply it to the spot. Cover it with a small piece of plastic wrap or plastic bag and tape down the edges of the plastic to hold the moisture in for a while.
XXX
Old 05-12-2010, 07:49 PM   #3
Tile stains
I should of looked further, it's Glazed Porcelain, Ragno Maraja 13 X 13 MT, would paint thinner still work on this to remove these dark wood stain droplets. There are 6 tiles with spots on them.
Old 05-13-2010, 07:45 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Porcelain tiles can have microscopic pores in the surface that will hold on to stains such as this. There is a chance it can be removed or at the very least reduced considerably. Try the poultice for a few days.
XXX
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
