Old 04-21-2010, 03:16 PM   #1
Ceramic Tile Staining Over Radiant Floor Heating?!
Hi folks,
I'm a co-owner of a flooring store and I ran into an issue I'd never heard of. Wonder if any of you have any ideas as to the problem.
Here is the issue: My customer installed a Single Fired Ceramic (not porcelain) tile floor in his basement over radiant floor heating 11 years ago. About 3 years ago he noticed that one of those tiles had a fleck of discolouration, now that discolouration has spread to another tile.
My suspicion is that he has a leak in the heating system that has caused a moisture issue from beneath the tile (because it seems to be spreading.) But that's all I can think of. I suggested he "rough" up the grout a little bit to see if it seems moist and that might help determine if that's the issue.
Any ideas, or has anyone ever seen this type of issue?
Thanks in advance!
rcuerrier is offline   Reply With Quote
Old 04-21-2010, 07:16 PM   #2
do an air or water pressure test to see if it holds
The older I get the better I was
Old 04-22-2010, 08:19 AM   #3
May give that a try! Thanks tpolk
Old 04-25-2010, 10:42 AM   #4
I would guess it probably is moisture issue as well. What I would do is call a couple of the tile company technical support 1-800 numbers...like Dal tile etcc....tell them the problem and see what they suggest. There is allot of new products out there every day that make for simple solutions.....good luck
Russman is offline   Reply With Quote
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Radiant Heat and Tile Texasguy HVAC 5 04-07-2009 11:14 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
