Old 02-13-2012, 07:40 PM   #1
ceramic tile on slab insulation options
I'm looking at putting ceramic tile in the basement but the more I read the more I see that you're supposed to have 2" of XPS insulation foam under the concrete slab. Seeing as my house was built 1959 I don't think I have 2" of XPS there and I can't imagine that it's cost effective to dig up the floor now to put the foam in.
I'd like to not put in one of those systems where you use 3 inches on just subfloor to get the insulation value in but I would like a thermal break so that the floor isn't freezing and if I choose to put heating under the floor that most of the heat will be going to the tile.
So, is there any product out there that I can use as a thermal break? I was hoping there would be something like ditra out there, but most of the products I come across are for floating floors (laminate etc) only. Anyone have any ideas?
thanks
MLMIB is offline   Reply With Quote
Old 02-13-2012, 11:58 PM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
If your looking to do floor heat
Scarify floor
Install Laticrete 170 sound & crack isolation mat
Install Laricrete floor heat
Bury in Laticrete 86 Latilevel
Set tile and grout
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 02-14-2012, 12:00 AM   #3
Tech Dawg's Avatar
Laticrete 254 Platinum would be a recomended thinset but if I'm not mistaken, you could use Sure Set...
Todd
www.aloneeagle.com
Repairing ceramic tile shower jimmyj Building & Construction 1 04-25-2011 09:09 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Ceramic tile on slab - install over adhesive left from vinyl tiles? softwareguy Flooring 1 08-23-2008 11:48 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
