-   -   ceramic tile on slab insulation options (http://www.diychatroom.com/f5/ceramic-tile-slab-insulation-options-133645/)
MLMIB 02-13-2012 07:40 PM
I'm looking at putting ceramic tile in the basement but the more I read the more I see that you're supposed to have 2" of XPS insulation foam under the concrete slab. Seeing as my house was built 1959 I don't think I have 2" of XPS there and I can't imagine that it's cost effective to dig up the floor now to put the foam in.
I'd like to not put in one of those systems where you use 3 inches on just subfloor to get the insulation value in but I would like a thermal break so that the floor isn't freezing and if I choose to put heating under the floor that most of the heat will be going to the tile.
So, is there any product out there that I can use as a thermal break? I was hoping there would be something like ditra out there, but most of the products I come across are for floating floors (laminate etc) only. Anyone have any ideas?
thanks
Tech Dawg 02-13-2012 11:58 PM
If your looking to do floor heat
Scarify floor
Install Laticrete 170 sound & crack isolation mat
Install Laricrete floor heat
Bury in Laticrete 86 Latilevel
Set tile and grout
:rockon:
Todd
www.aloneeagle.com
Tech Dawg 02-14-2012 12:00 AM
Laticrete 254 Platinum would be a recomended thinset but if I'm not mistaken, you could use Sure Set...
Todd
www.aloneeagle.com
