Old 08-23-2008, 08:27 PM   #1
Question
Ceramic tile on slab - install over adhesive left from vinyl tiles?
I'm tiling the Kitchen, which is on a slab.
The old vinyl (or similar) tiles were removed, but there's a very thin layer of what must have been the adhesive. It's black, but not sticky any more. I tried to scrape it off the floor, but it's really stuck to the slab.
Based on the age of the tiles (1960's), I've been told that it's possible that the glue contains asbestos.
Is it possible to lay ceramic or porcelain tile over this? I'd like to avoid disturbing this material if possible.
Any thoughts?
Last edited by softwareguy; 08-23-2008 at 08:29 PM. Reason: removed font format errors
softwareguy is offline   Reply With Quote
Old 08-23-2008, 11:48 PM   #2
Tileguy
JazMan's Avatar
Hi,
That black adhesive is called 'cut-back' and you can tile over it. It is recommended that you scrape as much as possible, leaving only an almost translucent film. This cut-back probably also may contain asbestos, so don't make dust with it. There are many modified thinset mortars that work well over cut-back. It'll say so right on the bag.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Tags
adhesive, asbestos, slab, tile
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
Will Ceramic Tile Stick to This? average Remodeling 3 06-28-2007 01:20 PM
Ceramic Tile Quality leted_82 Flooring 9 05-08-2007 11:53 AM
Adhesive of Slab nsb318 Flooring 1 03-01-2007 12:04 AM
