Old 03-17-2009, 10:13 AM   #1
Default Ceramic tile & paint
I have to remove paint (white latex) from a ceramic tile floor which appears not to have been sealed by previous owners (appears as if neither tile nor grout were sealed). The tile is brown 'pattern' (not one color) & textured. Have tried 'Goof Off' but it does not seem to penetrate enough to lift the paint to the surface. Any ideas would be appreciated.
BizR is offline   Reply With Quote
Old 03-17-2009, 11:17 AM   #2
011000100110111101101111
DangerMouse's Avatar
i'd try a paint stripper product such as 'strypeeze' to soften it first and then wipe the residue out with a terry cloth rag.
that should do it, i would think. be sure to follow instructions on the can in regards to ventilation, etc.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
DangerMouse is online now   Reply With Quote
Old 03-17-2009, 01:19 PM   #3
in the past I have had to do just that, remove paint from tile flooring. I have had some success with a heat gun to WARM the paint and then remove it by using a rough scrubbing pad and thinners ( depends on type of paint, oil or latex). Careful not to get tiles hot as they can break easily on you
cheers
fixrite is offline   Reply With Quote
More On This Topic
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio, and I’m here to show you one of my tile mosaic creations. This is a tile quilt; I made a quilt making pattern called “rob Peter to pay Paul.” Basically, what I did was this was... Read More »
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
How to Seal Grout
How to Seal Grout by Expert Village
Today we’re going to be sealing grout that we have reapplied in between the bathtub tiles. You want to seal it so it won’t mold or mildew or won’t start to flake out. What I use is a penetrating sealer and stone enhancer. The stuff is... Read More »
How to Seal Tile
How to Seal Tile by eHow.com
Most tiles used in homes are glazed, and the glazing process creates a seal. But if you use porous materials, such as terra cotta, marble or slate, you will need to seal the tile to keep the surface looking good and to prevent stains on that surface you... Read More »
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 06:57 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 08:12 PM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 09:18 PM
Flat over Semi-Gloss dankreboot Painting 10 07-06-2008 12:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
