Old 12-25-2012, 01:38 PM   #1
FlyingHammer
Ceramic tile over vinyl?
Is it necessary to remove the existing vinyl flooring before I tile my kitchen? The house is built on a concrete slab. The vinyl appears to be original from 1993, and is tightly adhered. My first instinct is to scrape it all off, but then I got to wondering if it's really necessary. Seems like it would act something like Ditra if I just left it in place. Has anyone done this?
FlyingHammer is offline   Reply With Quote
Old 12-25-2012, 04:09 PM   #2
Super Moderator
Tile can be set over sheet goods--if the sheet goods are well stuck--are NOT a padded style--
And you can accept the fact that the tile will not be bonded as well as it would be over concrete or Ditra.
Use a modified thinset that is warrantied for use over sheet vynal or mix your own using unmodified mixed with liquid latex----
It is done frequently ----but there is an added risk of failure---
Old 12-26-2012, 06:45 AM   #3
Doer of Many Things
poppameth's Avatar
Yep can be done, but you are better off removing it completely. If you do leave it, use Ditra. There is an approved installation method for Ditra over vinyl.
poppameth is offline   Reply With Quote
Vinyl sheet tile install - remove or level ceramic? Craigkapo Tiling, ceramics, marble 3 01-21-2012 02:13 AM
Installing Ceramic tile over vinyl tile msrita Flooring 3 06-16-2011 09:01 AM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 02:42 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
