-   -   Ceramic tile over vinyl? (http://www.diychatroom.com/f5/ceramic-tile-over-vinyl-167342/)
FlyingHammer 12-25-2012 12:38 PM
Is it necessary to remove the existing vinyl flooring before I tile my kitchen? The house is built on a concrete slab. The vinyl appears to be original from 1993, and is tightly adhered. My first instinct is to scrape it all off, but then I got to wondering if it's really necessary. Seems like it would act something like Ditra if I just left it in place. Has anyone done this?
oh'mike 12-25-2012 03:09 PM
Tile can be set over sheet goods--if the sheet goods are well stuck--are NOT a padded style--
And you can accept the fact that the tile will not be bonded as well as it would be over concrete or Ditra.
Use a modified thinset that is warrantied for use over sheet vynal or mix your own using unmodified mixed with liquid latex----
It is done frequently ----but there is an added risk of failure---
poppameth 12-26-2012 05:45 AM
Yep can be done, but you are better off removing it completely. If you do leave it, use Ditra. There is an approved installation method for Ditra over vinyl.
