Old 10-16-2009, 09:44 AM   #1
Default Ceramic tile over interior stairs
I'm having my stair case redone. It presently has carpet over hardwood flooring. The tiler tells me his plan is to leave the hardwood and cover it with 1/4 durock then the tile...sound right to the professionals?
Pete
pglc is offline   Reply With Quote
Old 10-16-2009, 12:37 PM   #2
Tileman-Manufacturers rep
Pete,
NO, that is not right.
First of all you should know that tile on wooden steps can develop grout cracks at minimum. The hardwood should be removed, it's just too unstable. You then install plywood as/if needed and then you can use your favorite backer board or membrane underlayment.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 10-16-2009, 07:11 PM   #3
I wouldn't tile it if has any movement at all, triple stringers, 3/4 ply and solid as a rock, maybe.
R&D Tile is offline   Reply With Quote
Old 10-17-2009, 03:03 PM   #4
Stuck in the 70's
Blondesense's Avatar
If he were to leave the existing hardwood, add 1/4 inch durock, then probably another 1/4 inch or more for the tile and thinset he would be adding 1/2 inch to each stair. Most of the stairs won't matter as the ratio will be the same, but it would be evident at the top and bottom.
Is this significant enough to be a potential problem?
More On This Topic
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
Hi, I’m Faith, I’m here at Flat Fork Studio and I’m going to show you how to glue your mosaic pieces down to your final piece. And at this point I would use a thinset- a premixed thinset- and it comes from the hardware store already... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
Hi, I’m faith and I’m here at Flat Fork Studio and I’m going to show you how to use the tile nippers to round off the edges of your tile. Basically, the concept is that you’re trying to take small amounts of tile in order to kind... Read More »
Hi, I’m Faith Schexnayder and I’m here at Flat Fork Studios, and I’m going to show you how to draw out a pattern for your mosaic project. First of all, I have in mind to do a quilt pattern, which is very simple because it’s broken... Read More »
Removing Bathroom Ceramic Tile Layed in 1970 mark2741 Flooring 2 08-24-2009 10:23 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 08:12 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 02:08 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 05:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 04:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
