Old 09-01-2012, 05:08 PM   #1
Ceramic tile over Behr solid concrete stain
Is it possible to install ceramic tile on an outside patio in Florida (no freeze cycles) that has had Behr solid concrete stain applied. I was told that the stain would be a bond breaker. This is only a 144 square foot patio, but I don't want to have to grind all the stain off. Any suggestions?
freddyjoe37 is offline   Reply With Quote
Old 09-01-2012, 05:59 PM   #2
It's got to go.
Old 09-01-2012, 06:24 PM   #3
Super Moderator
I think you will need to grind that off,too.--Rent a floor buffer with carborundum stones---should be a quick job.
Call Latacrete customer service if you want the okay to go over that sealer---they may have a product that will work.
JetSwet (09-01-2012)
Old 09-03-2012, 06:45 PM   #4
Thanks for the responses. I will try my local big box and see if they have the carborundum pad that was suggested. This sounds a lot easier than using a grinder. Long time lurker, I usually have any questions answered by viewing the forums. Just tiled a bathroom using the info on here. Turned out great by the way. Thanks everybody.
Old 09-03-2012, 08:55 PM   #5
Super Moderator
Those carborundum block pads are very common---If the Depot doesn't have it --a local rental shop will---
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Behr solid stain is peeling, what can I Do? ktyms Painting 9 05-05-2012 10:26 PM
Pulling up tile want to change to stained concrete drkauf Flooring 1 03-19-2011 06:57 AM
Can I install ceramic tile onto an uneven and un-level concrete floor? Integraoligist General Discussion 17 02-03-2011 09:43 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 08:31 AM
