-   -   Ceramic Tile out of the question? (http://www.diychatroom.com/f5/ceramic-tile-out-question-168155/)
Cmas55 01-03-2013 04:30 PM
I recently started a bathroom remodel, first time attempting such a job, and was planning to put 12x12 ceramic tile down for the flooring.
After stumbling on to this forum, and reading a couple threads, I noticed the mention of "deflecto calculator", so I looked it up and used it.
According to the calculator, I have a deflection of L231, with 12ft 2x8 Joists of unknown wood, spaced 16" apart... which is a no go apparently for everything but wood and sheet vinyl.
Is there anything I can do to make the room acceptable for Ceramic tile, or am I stuck with the aforementioned wood or vinyl? Are there any other possible variables that may shift this in my favor, the idea of putting vinyl back down is quite a disappointment.
Thanks in advance.
poppameth 01-04-2013 06:58 AM
Basically you either sister in new joists alongside the old ones or you install a beam with proper support that runs under all the joists to effectively cut your overall unsupported span down.
cleveman 01-04-2013 09:32 PM
I've laid a lot of tile on 2x8 douglas fir floor joists spanning 12', 16" oc with 3/4" OSB sheathing, then 1/2" denshield. And I will continue to do so.
JazMan 01-05-2013 04:05 PM
Cmas55,
Your ratio might be a little better if you knew the species and grade. The calculator is a bit conservative. But you are a little below spec regardless. Chances are you could still get away with it, but no guarantee. Too much deflection along the joists is much more forgiving than deflection across the joists. (too thin or wrong subfloor sheet (s)).
You should stiffen the joists if you can. You might also look for a premium thinset called Reflex made by Hydroment. They claim success even at L240, (they, not me). It's not available in all regions though. (Another reason you shoulda listed where you are).
Jaz
poppameth 01-06-2013 12:05 PM
I agree with Jaz on this. The calculator is very conservative when you don't know the wood species. Just changing the wood back to douglas fir adds about 70 points back.
