Ceramic Tile Layout In Several Adjoining Rooms - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 06:13 AM   #1
Ceramic tile layout in several adjoining rooms
My son and I are about to lay ceramic tiles in several rooms: a dining room and kitchen and a parallel hallway plus another hallway at right angle to this hallway plus a bathroom off this hallway We are just not sure where to start or do we start in a few locations. Any suggestions would be appreciated
Johnnie3fingers is offline   Reply With Quote
Old 07-27-2011, 07:00 AM   #2
DIY staff
Rewards Points: 7,174
You are going to have to make a grid--The layout will take you some time---
I don't have time to spell it out right now---so I'll give you a short version---
a grid is usually four tiles---two tiles wide and two grout lines---Let's say your tiles are a perfect 12x12---and you choose a 3/16" grout line---
two tiles + two lines =24 3/8"
You will snap a chalk line as a starting point centered in the hall or where ever leads into the adjoining rooms---and start marking off your grid---do you like the size of the cuts at the walls ,doors and toilet hole? If so great the start line becomes your 'god' line .
If not---move the start line over to a place that will give you acceptable cuts .
Once you have a 'god ' line---spray that line with hair spray and start snapping all the lines in that direction,
Using a square---snap a start line in the other direction---measure and see if you like the cuts--
Move the line if needed-----then snap the rest of the grid.---Hair spray the chalk lines and start cutting and setting.
The directions are in the site some where ---try 'search' of wait for some one to explain better.
I have a couple of laser lay out tools that speed things up---but a ruler and square work just fine.
Johnnie3fingers (07-27-2011)
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 12:40 PM
Trying to install ceramic tile on unlevel floor in 1890's era house Kichigaidave Flooring 10 06-11-2010 12:43 AM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 12:04 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
