Ceramic Tile Installed On A Wall. - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 10:02 AM   #1
Ceramic tile installed on a wall.
I am intending to install ceramic tile on a bathroom wall, from the floor up to a height of about 3 feet. Currently, there is sheetrock on the wall. Do I have to remove that and install cement board or something? Will sheetrock not support the weight of the tiles? thx.
7preacher7 is offline   Reply With Quote
Old 11-21-2009, 10:21 AM   #2
There's more to consider than the weight -- moisture for example. More information would help you get the correct answers.
roxksears is offline   Reply With Quote
Old 11-21-2009, 10:40 AM   #3
Remodeling Contractor
you can install the tile on sheetrock except in the shower stall area which will need CBU and waterproofing
Old 11-21-2009, 11:42 AM   #4
It is in a bathroom with no shower, so low moisture. Just didn't know if the paper might peel off of the sheetrock. Thx
Old 11-21-2009, 01:35 PM   #5
It will not peel off. You will be fine. A better job would be to use the CBU but this is not required.
Old 11-21-2009, 02:05 PM   #6
I appreciate it, thx Bob.
Tags
backer board , bathroom , ceramic tile , wall tile
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 10:01 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
