-   -   Ceramic tile installed on a wall. (http://www.diychatroom.com/f5/ceramic-tile-installed-wall-57659/)
7preacher7 11-21-2009 10:02 AM
I am intending to install ceramic tile on a bathroom wall, from the floor up to a height of about 3 feet. Currently, there is sheetrock on the wall. Do I have to remove that and install cement board or something? Will sheetrock not support the weight of the tiles? thx.
roxksears 11-21-2009 10:21 AM
There's more to consider than the weight -- moisture for example. More information would help you get the correct answers.:)
Bob Mariani 11-21-2009 10:40 AM
you can install the tile on sheetrock except in the shower stall area which will need CBU and waterproofing
7preacher7 11-21-2009 11:42 AM
It is in a bathroom with no shower, so low moisture. Just didn't know if the paper might peel off of the sheetrock. Thx
Bob Mariani 11-21-2009 01:35 PM
It will not peel off. You will be fine. A better job would be to use the CBU but this is not required.
7preacher7 11-21-2009 02:05 PM
I appreciate it, thx Bob.
