Ceramic Tile Floor Prep - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 12:33 PM   #1
Ceramic tile floor prep
Hello Folks,
First time poster here. This looks like a good forum. I did browse through some threads before deciding to post. Apologize if this appears similar to previous threads.
We are remodeling our upstairs bathroom. At this point, I am prepping the floor for ceramic tile. The existing floor consisted of sheet linoleum glued like crazy to 5/8" plywood which is over top of 1/2" plywood subfloor (nailed to the floor joists). In order to remove the linoleum, I ended up ripping out the 5/8" plywood. Now I am in the process of putting down fresh 5/8" plytanium over the 1/2" plywood which orients the 5/8" perpendicular to the joists. Should I be screwing and nailing the 5/8" down? I have 1/4" hardibacker that will be laid in thinset and screwed down over top of the 5/8". I have already started on the nailing of the 5/8" following the nailing that was done on the previous 5/8". Do I need to be hitting the joists on the 5/8" and what is the proper fastening schedule?
Thanks!
sudnvictory is offline   Reply With Quote
Old 01-21-2013, 12:47 PM   #2
Rewards Points: 13,472
Should be making sure the seams do not line up with the seams below, not nailing into the joist, every 4" on the outside edges and every 6 to 8' in the field.
Use ring shanked underlaymant nails.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
oh'mike (01-21-2013), sudnvictory (01-21-2013)
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 11:29 AM
ceramic tile stain kivy Flooring 10 04-09-2012 06:57 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 12:07 AM
