Ceramic Tile Floor In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 11:17 PM   #1
Handyman
brucem609's Avatar
Rewards Points: 79
Ceramic tile floor in basement
Ok, so I have a customer whose basement I am fully remodeling. We are just about ready to put in the floor. She has decided on ceramic, against my advice. The floor currently has grey paint on it, but it has worn in some places. The question- Will I be able to,use thinnest right over this paint or do,I need to first remove the paint? I have never put ceramic tile in a basement due to the cold. Also do I need to add anything to fortify the thinset? There is no evidence of any water in the basement so I am not concerned about that. Any other concerns?
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
Old 03-29-2013, 07:41 AM   #2
DIY staff
Rewards Points: 7,174
You should remove or at least scarify the old paint----I suggest you rent a floor buffer with carborundum stones--this will clean that off very quickly---
Use a good quality powdered modified thinset----
The temperature in a basement will not affect a properly set floor---tile can be set outdoors and inside commercial refrigerators----
Old 03-29-2013, 02:48 PM   #3
Rewards Points: 87
Perhaps Bruce is thinking more of the floor being cold to walk on, barefoot in the winter time, compared to softer floorings?
huesmann is offline   Reply With Quote
Old 03-29-2013, 10:40 PM   #4
Rewards Points: 920
Yeah, if you're worried about the basement being too cold to have tile, just heat it up a bit while you are doing the work, or wait and do it in the summer.
cleveman is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
how do I attach ceramic tile to ceramic tile? porchhen9 Remodeling 8 07-31-2011 03:59 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Type of Tile for Basement Bathroom MrBill_DIY Flooring 1 05-02-2010 04:08 PM
Basement flooring. Tile? HuskySkull Flooring 1 08-11-2007 12:45 AM
