-   -   Ceramic tile entry way question. Help! (http://www.diychatroom.com/f5/ceramic-tile-entry-way-question-help-13560/)
bmschoen 11-19-2007 10:27 AM
Our front door opens up into our living room that is currently wall-wall carpet. I want to cut the carpet out in front of the door a little wider than the doorway and about as far out and lay ceramic tile to create a little place in front of the door to kick you shoes off, etc. How would I go about doing this. Could I just cut the carpet and pad down to the wood floor, screw a piece of cement board down and glue the tiles to it? What about a transition between the carpet and tile, how is this done? Thanks!
The Floor Guy 11-19-2007 02:59 PM
Suggestion to Tile Entry
Floor prep is everything. Let's correctly identify your sub floor. Is this on the second floor or is the a living area beneath. If not and your home has a crawl space underneath to the earth. You may have to reinforce the existing sub floor if it is wood. Check to see underneath the carpet if you have a plywood,plank or composite-flake board.
As far as adhering tile to a new surface, you are correct to consider cementboard. I would suggest you not screw the board into a wood sub floor because the screws will back out use underlayment nails or roofing nails instead.
The correct choice of stuff to adhere the tile is mortar- thinset with additive.
A correct transition to finish the surface would be a metal trim design for tile application ie. Schluter trim.
Keep ion touch with your project
