Ceramic Tile On Drywall - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2005, 09:06 AM   #1
Ceramic Tile on Drywall
I have a raised bathroom in my finished basement due to an upflush system. The step going up into the room is finished with drywall....Can I put ceramic tile onto the drywall as a toe kick going into the bathroom? Will the tile stay adhered to the wall or do I need to put something else there so it remains permanent? Thanlks
fisher501 is offline   Reply With Quote
Old 12-02-2005, 07:37 PM   #2
jproffer's Avatar
Rewards Points: 714
Take down the rock and put up Durock or Hardibacker or some other brand of concrete board. Tile over that, you should be fine. BTW, tile isn't going to take a lot of "kicking" as a toe kick, but as long as you're easy on it, you'll be OK.
jproffer is offline   Reply With Quote
Old 12-02-2005, 11:03 PM   #3
Contractor
jp called it, can't add more.
Teetorbilt is offline   Reply With Quote
Old 03-20-2011, 04:48 PM   #4
They now have a special material that you can put on the sheetrock and then tile over it.
IceT is offline   Reply With Quote
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 07:56 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
