Ceramic Tile...Do I Have Enough Sub Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 02:51 PM   #1
Ceramic Tile...Do I have enough sub flooring?
Hello, I am looking to rip up the existing linoleum in our bathroom. The linoleum is glued to 1/2 inch plywood that is attached to 1 inch particle board. The total subfloor is 1 1/2 inches thick.
Would it be possible to rip up the linoleum and remove the small amount of glue and lay ceramic tile with the existing subflooring? Or would it be best if I still lay down 1/4 inch cement backer board on top of everything? Thank you very much for the information.
Pope1605 is offline   Reply With Quote
Old 05-06-2013, 06:47 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
You would have to find out if its OSB ply or MDF 1st. Give us specs on joists as well size and dementions.
JetSwet is offline   Reply With Quote
Old 05-06-2013, 09:26 PM   #3
Rewards Points: 4,792
Cement backer board does nothing to increase structural stiffness. Or at least you shouldn't count on it.
1 1/2" of subfloor is plenty. However thickness isn't everything. There is joist size, joist spacing, and other miscellaneous things.
I don't like cement backer board very much. I far prefer Ditra.
jeffnc is offline   Reply With Quote
Is glazed ceramic tile permeable to vapor? Pamp81 Flooring 19 06-28-2013 03:36 PM
Slate or ceramic tile Flooring questions oldschoolboy Flooring 11 07-02-2011 10:49 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
