?-ceramic Tile On Concrete Floor-? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 10:47 PM   #1
?-ceramic tile on concrete floor-?
Where is a good place to learn the process of laying ceramic tile onto a concrete slab. I live in Northern Minnesota and experience every season (to an extreme). Do I need to prep the floor with something or lay down some kind of membrane? thanks for your time and patience (plus knowledge).
studio_arts is offline   Reply With Quote
Old 01-08-2012, 10:55 PM   #2
Rewards Points: 13,274
Depends, what's the floor look like?
Cracks, gets wet when it rains, has it been sealed or painted, is there lots of low areas?
Old 01-08-2012, 11:20 PM   #3
The floor had one noticeable crack, It has not been sealed or painted, it is relatively level But I am not there to monitor it twenty four seven except in the warm months. There is some moist looking areas after the snow melts, but there is usually a lot of snow.
Old 01-08-2012, 11:48 PM   #4
I would lay Schluter Ditra on top of the concrete and then lay your tile. You CAN get tile to adhere very nicely to concrete but any movements from your floor will transfer right to your tile and lead to cracked grout and possible cracked tiles.
The Ditra gives an uncoupling membrane between your floor and your tile. Typically with Ditra you will use a modified thinset to adhere the Ditra to the floor but with concrete you should use an unmodified thinset to set your ditra to the concrete and also to set your tile to the Ditra.
Also, if your floor is going to be in extreme conditions, very hot to very cold, you might want to use an epoxy based grout which is flexible and may not crack.
stankholio is offline   Reply With Quote
Remove floor tile set in 3/4" concrete Dmeyr Flooring 31 12-14-2011 12:07 PM
Please help! How to fix hole in concrete floor before I tile tomorrow? PatrickGSR94 Flooring 14 03-15-2011 07:44 AM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 07:53 PM
ceramic tile to wood floor threshold bjs Flooring 23 11-28-2008 09:35 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 08:49 PM
