Ceramic Tile Clean Up & Reuse - Flooring - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 12:44 PM   #1
Question
Ceramic Tile clean up & reuse
I need to reuse some ceramic tile that was originally laid with Portland Cement thin-set. How do I clean up these tiles to reuse? Is there a solvent of some sort that will dissolve the thin-set but not harm the ceramic tile? I could soak them in a solution that would clean them up for reuse?
Last edited by Pamwren@aol.com; 01-31-2012 at 11:43 AM. Reason: Further clarification.
Pamwren@aol.com is offline   Reply With Quote
Old 01-30-2012, 12:53 PM   #2
DIY staff
Rewards Points: 7,174
Angle grinder with a wire wheel--or a diamond cup would be fastest---table belt sander might work--
I think you will have to experiment---Angle grinders are cheap and handy to have around the house--
Tags
ceramic tile
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 12:40 PM
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 10:09 AM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 12:04 AM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 10:37 PM
Cleaning ceramic tile surfaces hexland Flooring 2 07-31-2006 10:24 AM
