Ceramic Tile On Bouncy Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 09:21 PM   #1
Question
ceramic tile on bouncy floor
I am about to install ceramic tile for small laundry room In my basement.
Now, 5/8 plywood has been nailed to concrete slab.
But I found some part of the plywood is little bouncy even if I put more nails.(may be the plywood is pretty rigid and the slab is uneven.)
Is there any way to secure the subfloor before installing ceramic tile?
And, what type of underlayment or backer board do I use?
Wire mesh? cement board? dentshield board? Or another layer of plywood to stop bounce?
Thanks for your advise!
chobio is offline   Reply With Quote
Old 11-04-2011, 09:28 PM   #2
normally you just tile directly to the concrete.
Old 11-04-2011, 09:29 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
First thing is take up the plywood.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 11-04-2011, 09:53 PM   #4
Wood on concrete will rot. Take up all wood and use thinset mortar to set tile. Use a 1/4 by 1/4 trowel to spread mortar.
plowboy is offline   Reply With Quote
Old 11-04-2011, 10:23 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
I definitely agree you need to remove the wood and tile either on the concrete or over a membrane such as Ditra.
Use the trowel that is appropriate for the tiles you're installing.
Jaz
Old 11-05-2011, 04:47 PM   #6
Thanks guys
Thanks for all the reply, guys.
Actually, I forgot to say that there is dimple membrane between concrete slab and plywood. So, I don't have to remove the plywood, do I?
I am about to install ceramic tile.
Do I need cement board or something before thin set mortar? This small room is going to be laundry room.
Old 11-05-2011, 04:54 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Chobio did you come here for answers or do you just want to make new rules as you go? Listen to these guys. You can not install tile over what you have there and plywood should never be installed over concrete.
Old 11-07-2011, 09:27 AM   #8
Rewards Points: 272
I think he might be trying to say that there is drycore down over the concrete. Just a thought.
fixrite is offline   Reply With Quote
Old 11-07-2011, 10:12 AM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
I don't think he's referring to Dry-Core, but no matter. You can't tile over Dry-Core either. Even with plywood and concrete backer over it.
Jaz
Old 11-07-2011, 10:57 AM   #10
Rewards Points: 272
Hey Jaz. I did a little looking and according to dricore's website, you can. I have read many of your posting on here and respect your opinion very much, so please don't think I am trying to be a smart azz or anything like that. Here is a link to it, www.dricore.com/en/dinstal.aspx. They do mention that one would need to install cement board over it as well as securing it to the flooring with screws. I guess it would be something that could be done but generally not the best choice is what I gather from it all. Once again I am not trying to be a smart azz.
Old 11-07-2011, 12:58 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dricore is one of those products that wants to be all things to all people. If one were not to follow their recommendations to the letter, tile on Dricore would not work out very well. We have people coming here all of the time that want to take short cuts or save money or argue about prescribed proven methods. Not saying that is the case here but just sayin'. If some specific measures are incorporated in a project such as this, it ain't gonna work.
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Ceramic Tile Staining Over Radiant Floor Heating?! rcuerrier Flooring 3 04-25-2010 09:42 AM
Installing ceramic tile on garage concrete floor erotavlas Flooring 11 02-27-2010 11:01 PM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 07:46 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
