Old 04-08-2009, 01:39 PM   #1
Ceramic tile in basment
I read and read and read but did not find anything to answer my question
Do I have to use self leveling ? the slab concrete floor I have now is in ok shape but have little dips and holes from the old carpet nails mostly around the walls and in door entrances
what type of morter should I use to lay the tiles down ? I know I dont have to put a sub floor down as most of the threads on here say so
wanna see pictures ? the basment will have the same tile through out a roughly 900 sq/ft area
Please dont mind the colors on the stairs it will be sanded down and stained I am using a dark charcoal / black tile
blk90s13 is offline   Reply With Quote
Old 04-08-2009, 02:30 PM   #2
Remodeling Contractor
Use modified thinset to set the tile. Best to first coat the concrete with an cleavage membrane. a membrane is advised due to the cracking potential of concrete - and the resultant "telegraphing" into the tile installation. You could use Ditra for this but there are cheaper options that will work fine if you floor is not already showing major cracking. Clean the floor thoroughly. No need for a subfloor to set tile on concrete.
Old 04-08-2009, 02:41 PM   #3
Yea the floor will be vacummed and them mopped a couple of times till it shines
I am not sure what a cleavage membrane is tho can I just ask for it by name in the local home depot ?
Is a modified thinset some what a self leveling and mortar in one ? sorry I need a little more details
Thanks for all your help
Old 04-08-2009, 02:46 PM   #4
modified thinset is thinset mixed with a latex additive to increase flexibility. It will not work like self leveling compounds. You will only need these if you have larger dips. For smaller dips the thinset, which is like concrete will easily float these out and fill small holes. Buy your supplies from a tile supplier not HD... Ditra is available at HD but only in smaller rolls. Noble and CS make membranes also.
Old 04-08-2009, 04:13 PM   #5
Tileguy
JazMan's Avatar
Thanks for the laugh..........
You asked; "I am not sure what a cleavage membrane is tho can I just ask for it by name in the local home depot ?"
You don't know how funny that is. If you asked someone at those big box stores that question, they might laugh too and then think you were the one that didn't know anything?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 04-08-2009, 04:17 PM   #6
Jaz
What ? Bob Mariani is trying to set me up imagine it was a woman working the store and I go up to her and say I am looking to get some CLEAVAGE MEMBRANE
Old 04-08-2009, 04:32 PM   #7
Jaz and others.. was not trying to be mean or funny.. this time... read this one..
http://www.tileusa.com/loose-crackedtile_faq.htm
Jaz this is a typical discussion and material used on TCA... you I thought would know this one for sure.
Old 04-08-2009, 05:49 PM   #8
Great info thanks for the link Bob.
Old 04-08-2009, 06:09 PM   #9
Nothing wrong with thinset from HD, Versabond and Flexbond are very good, if there are no cracks in that slab, tile directly with Flexbond if you like, if cracks, yes, use a crack isolation membrane, there are many out there.
R&D Tile is offline   Reply With Quote
Old 04-08-2009, 06:34 PM   #10
hair pin crack in one area the slab is as old as the house which was build in 1953
Old 04-08-2009, 07:17 PM   #11
Then you can just tile over the concrete as is after a good cleaning.
Old 04-08-2009, 09:57 PM   #12
Tileguy
JazMan's Avatar
Bob,
Are you trying to teach me something about tiles? I don't think so. I was in the tile biz before you were born. And, it's now officially TCNA.
Jaz
Old 04-09-2009, 05:17 AM   #13
Bob,
Jaz
Of course I am not. But I posted what think was correct and if you disagree, I post why I think it is right. Why? I am always learning. And you can learn many wrong things in this industry as well as read many incorrect things. So I am going back and forth with you as the obvious teacher in this and refining my own knowledge base on these matters. And I would not want to repeat any mistakes in future posts. So pick on my posts as much as needed. It can only help to make things clearer and increase my knowledge and other that of other members reading these threads.
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 01:40 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
