Old 01-12-2012, 03:54 PM   #1
Ceramic tile around a basement pole
I am tiling around a bar I installed in my basement. I probably should have planned my job around the pole, but I thought it would be more important to have full tiles on the outer edges. Of course, the pole lands right in the middle of a tile. I'm installing in a diamond pattern (if that matters). Any ideas on the cleanest way to install around the pole? I would like to minimize the unsightly cracks, etc.
Thanks in advance!
koz123 is offline   Reply With Quote
Old 01-12-2012, 04:13 PM   #2
I can fix that!
I think the only option you have is to cut the tile in two pieces. I would cut it so the seam passes through the middle of the pole and plan on a narrow grout line. Then cut out the two half circles.
kuhlman is offline   Reply With Quote
Old 01-12-2012, 07:10 PM   #3
firehawkmph's Avatar
You could also get some small decorative tile (mosaics maybe) and use them around the pole instead of the one piece of your field tile.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-13-2012, 04:15 AM   #4
Stuck in the 70's
Blondesense's Avatar
Are you planning on covering the pole with anything?
Blondesense is online now   Reply With Quote
Old 01-13-2012, 06:34 AM   #5
Super Moderator
You will need to cut the tile---That's called a 'Dutch Man' ---don't try to hard to disguise the cut--it needs grout--Just plan its placement so that it looks good with the tile---
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
re: new ceramic floor in basement gramps416 Flooring 6 12-27-2008 01:50 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Basement flooring. Tile? HuskySkull Flooring 1 08-11-2007 12:45 AM
