Ceramic On Sealed Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 07:51 PM   #1
JHill's Avatar
Ceramic on sealed concrete
I'm getting ready to put a ceramic floor in the basement bathroom (2 year old home). I understand that it's OK to put the tile on the concrete but about a year ago I painted on the behr's basement sealer to reduce the concrete dust.
Can I apply the thin-set on top of the sealer or do I need to prep this floor with something else first?
Thank you in advance for your responses.
JHill is offline   Reply With Quote
Old 01-22-2008, 08:35 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
You're not gonna get as good a bond as you need most likely? Test the slab for porosity by placing several drops of water in various spots. The water should soak in within 10-15 minutes. If possible compare with untreated areas.
If that is inconclusive, bond several small samples to the floor using a good grade modified thinset mortar. Try to remove using lateral force after 7-10 days.
Jaz
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
