Ceramic Over Old Hard Wood Floor???? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-12-2007, 07:11 PM   #1
Question
Ceramic over Old Hard Wood Floor????
1920's house with wood floors, I need to install new ceramic floor to the bathroom. Do I need to ripout the existing hardwood floor and replace it with a subfloor? Or do I put a subfloor over the hardwood? I worry about the give of the floor, although it's in fairly good shape for it's age. Or can I put a backer board right over, still the flex I am concerned about. I just want it to right the first time.
cuinthemoon is offline   Reply With Quote
Old 08-13-2007, 09:23 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
The hardwood has to go. Install new plywood underlayment of the suficient thickness over properly fastened subfloor. You probably have 1x6 on a diagonal subfloor? Come back for instructions on how and what.
Once the underlayment is installed, install a tile backer board or isolation membrane.
How about the joists? What size, type, condition, spacing and unsupported span. If this isn't right the job fails.
Jaz
JazMan is online now   Reply With Quote
Urgent Help Needed - Ceramic Floor MarkD200 Flooring 8 08-13-2012 11:24 AM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Wood floor help/suggestions bigboyjoel Flooring 18 12-31-2008 01:02 PM
Hard wood floor install help helpless handyman Flooring 13 06-04-2007 09:12 PM
Leveling wood floor helpless handyman Building & Construction 1 10-17-2006 11:06 AM
