Old 09-28-2009, 05:36 AM   #1
Cement floor dust
The last tenant, having removed the laminated floor, left the showroom/warehouse floor in bare cement. After thoroughly washing the cement floor, I moved in, putting up shelves resting immediately on the bare floor. Soon after, I found dust covering everything everyday even when the windows and doors are closed for long periods. When there are more people moving around, you can actually see black dust like dried powder on the floor.
Since my shelves are all in, I can either lay linoleum on the floor by cutting around the legs of the shelves or apply a coat of matt polyurethane varnish on the floor and again around the legs. Moving out temporarily is not an option as it is too expensive.
My choice is matt polyurethane. Will this work? Can it be done as the floor can only be mopped/wiped? Will it remove the dust long enough to varnish? Is this a safe long term solution? I am equally concerned about long term cement dust or fumes from varnish on the lungs.
diyhopeful is offline   Reply With Quote
Old 09-28-2009, 07:10 AM   #2
the Musigician
DangerMouse's Avatar
Cement floor dust
varnish fumes go away, cement dust does not.
concrete will continue to produce dust unless sealed/coated.
i'd vacuum, damp mop, coat when dry with sealer.
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
DangerMouse is online now   Reply With Quote
More On This Topic
Designing and installing a library can be an expensive task. However, even the poor student can scavenge materials readily available and still attractive. In truth, books shelved away in a finished library tend to see very little use, whereas a library... Read More »
In our home renovation, we built a new entryway. What we did was this area that you see here connects with a long rock porch that goes around our house. This area, the full length of our house, was a cement porch. It was just bare cement and it went down... Read More »
Hello! My name is Judy Williams on behalf of Expert Village and today we’re talking about different ways to decorate your living room on a budget. There are many ways to use rugs in budget decorating. I’ve selected as I said, a semi-antique... Read More »
Cork, a renewable resource, comes from the bark of the Mediterranean cork oak tree. Every 9 to 10 years, cutters carefully harvest cork bark without harming the host trees. Through a process of grinding and baking, craftsmen create cork flooring sheets... Read More »
Hi, I'm Jon on behalf of Expert Village. In this video clip we'll be finishing our project. Once our stain has dried over night, we are ready to put our finish on our project. Now before I put the finish on, I need to take a tack cloth and rub that all... Read More »
installing Slate title to outdoor cement Matky Flooring 41 07-22-2009 04:14 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
