Cement Crack Sealer Or Cement Resurfacer To Fix A 1/8" Crack - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 11:50 AM   #1
Cement Crack Sealer or Cement Resurfacer to fix a 1/8" crack
Hi ,
I am preparing my cement subfloor to install a laminate floor. I have a 1/8" crack about 8 feet long. I don't see a noticable difference in height of both of the sides of the crack, however, it does look like the crack is very slightly raised up.
HomeDepot sells Quikrete Concrete Repair, Quikrete Gray Concrete Crack Seal, and Quikrete self-levelling Polyurethane Sealant.
I called the company and they are telling me that I should not use any of the above because they are caulk based and are not meant to be covered. They said that I should be using the Vinyl cement patcher or the quikrete cement resurfacer.
What do you think is the best way to handle this crack, before I put down the underlayment and laminate?
toofan9 is offline   Reply With Quote
Old 08-03-2012, 07:37 PM   #2
Too Short? Cut it Again!
I would use one of the concrete restoration and repair products from Abatron. Call customer support to see what they recommend.
Cement Slab Perimeter Crack KNRE Building & Construction 3 07-07-2011 11:34 AM
Why would the cement they poured crack? In a day! Nosmos10 Flooring 4 05-06-2011 08:27 PM
Interior Cement Wall Crack beleazer Carpentry 7 11-22-2010 07:08 AM
can i mix asphalt sealer and cement ???? jake trudell Building & Construction 1 07-27-2010 02:08 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
