Cement Board Vs. Ditra - Flooring - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 05-18-2017, 08:58 AM   #1
Rewards Points: 790
Cement board vs. Ditra
We would like to install thin brick (about 5/8" thick) in for our mudroom floor and mudroom bath. We only have about 175 sq ft or so, but I am wondering what would be the best substrate for the brick? Do I use 1/2" backer board, or should I consider a underlayment like ditra or something similar?
I like the idea of not building up the floor height another 1/2" with backer board, but will do what's best. FYI, current subfloor is 3/4" ply, joists 16 o.c.
cibula11 is offline   Reply With Quote
The Following User Says Thank You to cibula11 For This Useful Post:
BayouRunner (05-19-2017)
Old 05-18-2017, 10:18 AM   #2
ZZZZZ's Avatar
Rewards Points: 2,778
Re: Cement board vs. Ditra
1/4" backer board, not 1/2", is typically used for floors.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 05-18-2017, 12:32 PM   #3
Rewards Points: 790
Regardless, is backer board no longer the best option given the rolled products like ditra,etc? Is there a reason why one would use one product over the other?
MTN REMODEL LLC likes this.
Old 05-18-2017, 12:47 PM   #4
ZZZZZ's Avatar
Well, Ditra is a premium product that is considered an "uncoupling membrane." It provides a degree of protection against cracks in the tile due to expansion/contraction of the underlying substrate as well as deflection of the floor joists. Cement board is stiff and unforgiving.
Cement board is much less expensive but it requires more expensive modified thinset. Ditra uses unmodified.
This article provides a good summary of pros and cons of each method.
https://www.thespruce.com/can-i-inst...lywood-1822594
Old 05-18-2017, 02:42 PM   #5
Rewards Points: 44
Ditra requires modified thinset to bond it to the plywood and unmodified to bond the tile to to the ditra. That's the instructions I remember when I used it.
abrowning is online now   Reply With Quote
Old 05-18-2017, 03:13 PM   #6
ZZZZZ's Avatar
Yes, thanks for the clarification.
Old 05-18-2017, 05:08 PM   #7
Rewards Points: 734
Ditra is only 1/8" thick so that will save you an 1/8" over backer. Is your "thin brick" rated for floors?
BIG Johnson is offline   Reply With Quote
Old 05-18-2017, 09:54 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 412
Thin brick for a mudroom floor? Doesn't sound like anything I'd recommend.
In addition, even though this product isn't natural stone, I would put it in the same category which means it's a good bet the joists system and for sure your single 3/4" subfloor is not adequate.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
abrowning (05-19-2017)
Old 05-19-2017, 10:01 AM   #9
Rewards Points: 790
Jaz
Why would you not recommend thin brick? 3/4" subfloor not adequate? Why?
Old 05-19-2017, 10:03 AM   #10
Rewards Points: 790
It says it's rated for floors as long as appropriate substrate is used (the specs make mention of subfloor similar to tile, but doesn't specify the exact type)
Old 05-19-2017, 10:15 AM   #11
Rewards Points: 848
Brick is soft and does not wear well on a floor would be my best guess as to why Jaz would not choose it; it's at least part of why I would not choose it.
stick\shift is offline   Reply With Quote
Old 05-19-2017, 10:17 AM   #12
ZZZZZ's Avatar
I would bet it's not actual "brick", but porcelain made to look like brick.
BIG Johnson likes this.
Old 05-19-2017, 10:34 AM   #13
Rewards Points: 734
That'd be my guess if it's rated for floors. Probably supposed to mimic pavers. Not my taste but it's also not my house.
https://s-media-cache-ak0.pinimg.com...31848d3c3f.jpg
Old 05-19-2017, 11:11 AM   #14
Rewards Points: 790
Its a brick veneer that is cut from the face of actual antique bricks. It's an actual brick, not a tile or porcelain look alike. The picture above is essentially what it looks like.
Old 05-19-2017, 01:09 PM   #15
ZZZZZ's Avatar
In that case, I would research it more on the net. That's a non-standard product and application.
I would go with cement board, and possibly use a brick mortar rather than interior tile thinset.
Grouting brick would be difficult, as the face of the brick would suck up regular grout like a sponge. You might have to go with mortar applied with a cement bag or something similar.
I wonder what our resident tile guru Jazman will have to say on the matter.
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
cement board on top of cement brim in washroom avi Remodeling 9 09-08-2011 07:05 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
