Cement Board Seaming - 911! - Flooring - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 11:34 AM   #1
Cement board seaming - 911!
Hey all, i've been using these forums as an aid to my first home project, replacing our kitchen ceramic tile with a nice looking porcelain tile.
There was a few cracks in the old floor so i decided to tear it up and underneath i found that the tiles were set in mortar and wire mesh. I decided to go with cement board for my new tiles and laid it out with 1/8 - 1/4" gap in between all seams and edges. I used 3x5' Wonderboard with Rona brand polymer modified mortar and cement board screws 6" o/c.
My problem: on the cement board it said that wrapped edges (the 5' edge, long ways) need not be taped/mortared, so for the most part I only taped and mortared where two unwrapped 3' wonderboard edges met. keep in mind i left a small gap between all wonderboard edges, despite what i now see online to butt them and leave gaps at the walls..
1. is the fact that i didnt butt the wonderboards going to be a problem?
2. will the untaped 5' edges be a problem for the tiles ?
If more info is needed please ask, this is an emergency as I am about to lay my tiles right now and dont have any more fiberglass tape!
example of an untaped, wrapped 5' edge
Jeffs1stHome is offline   Reply With Quote
Old 10-16-2012, 05:41 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
Where did you read that WonderBoard on floors has to be butted together taped on the 'wrapped 5' sides?
WonderBoard should be gapped 1/8-3/16" on all sides. The un-trimmed 5' sides do not require the special mesh tape, (just the 3' sides), but you can tape all the sides if you want to.
Jaz
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 05:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
Laying cement board on top of leveling concrete. dswenson Flooring 3 01-04-2012 08:26 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
