Old 03-11-2013, 05:58 PM   #1
cement board over 3/4 sub floor for tile
how thick of cement board is needed over 3/4 tg plywood subfloor on 24" ctrs to support tile
saltE is offline   Reply With Quote
Old 03-11-2013, 06:51 PM   #2
1/4" is what's used on floors.
I'd play it safe and add at least 3/8 underlayment rated plywood before the tile board.
Do not have the seams line up with the seams below, fasten ever 4" on the edges and 6 to 8 in the field, do not attach it to the joist and do not use any glue.
You do know there needs to be thin set under the tile board right?
Old 03-11-2013, 08:01 PM   #3
Tileguy
JazMan's Avatar
Welcome saltE,
I think Joe missed the 24" o.c. part due to the malfunction. It's not a matter of suggesting, but you must go with an underlayment. The thicker the better, but need to know more.
Tell us the type and size of tiles you're planning. The type and size of the room and your location. The style of house, type of substrate, age and what's there now etc. We may need to know more, but good to start with just this info. .
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 05:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
Laying cement board on top of leveling concrete. dswenson Flooring 3 01-04-2012 08:26 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
