Old 12-20-2010, 06:48 PM   #1
Cement backer board over kitchen concrete slab
Hi! All, I have a question regarding the ½” hardie cement backer board apply on concrete slab.
The kitchen that I’m working on has concrete slab, I’m putting a 3/8” porcelain tile in the kitchen floor. I want to raise the floor as much as possible to match the adjacent living room floor level (about 1-1/8”).
So I’m planning to apply ¼” thin set over concrete slab, then put ½” hardie backer board over it, then lay down ¼” thin set on top, and put the 3/8” porcelain tile at last. (the whole assembly may not be 1-1/8” but close enough for me)
I know that hardie manuf. won’t warranty their product if it applies on the concrete slab directly. I also know that many people in the forum points out that I should not do it either. Here are my questions:
1) If I don’t care about the factory warrant, do you guys think that it is OK to use hardie backer board over concrete? If not, why?
2) How do I secure the board to the slab, would thinset be enough, or do I need to put additional screws to the slab?
3) What screw should I use?
4) What is the better way to raise the floor other than using backer board? I try not to use self-leveling concrete or similar method since it is too difficult for me to do. Do you guys have other recommendation?
Thanks a lot for your help
gtimk4 is offline   Reply With Quote
Old 12-20-2010, 11:59 PM   #2
I think the best way to raise the floor is to install a mortar bed but if you want to install the backer board make sure you use a notched trowel and thin set mortar to bond the cement board directly to the concrete. No screws needed.
epson is offline   Reply With Quote
Old 02-19-2012, 03:46 PM   #3
I am doing almost same project right now.
I am working on 1/2 bathroom on the 1st floor. Its about 27 sq ft. I removed old tiles already with hammer and pry-bar. I damaged mud bed under the tiles though, so I had to remove it too.
So now I guess I have to chose between SLC or Mortar Bed since I had Total Fiasco with CBU over Concrete Slab. Its like glueing two pieces of metal with Crazy Glue.
almazon is offline   Reply With Quote
Tags
backer board, kitchen flooring, tile
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 12:28 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Cement backer board - which to use? manhattan Building & Construction 3 09-14-2009 04:57 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 09:55 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
