Cement backer board over kitchen concrete slab
Hi! All, I have a question regarding the ½” hardie cement backer board apply on concrete slab.
The kitchen that I’m working on has concrete slab, I’m putting a 3/8” porcelain tile in the kitchen floor. I want to raise the floor as much as possible to match the adjacent living room floor level (about 1-1/8”). So I’m planning to apply ¼” thin set over concrete slab, then put ½” hardie backer board over it, then lay down ¼” thin set on top, and put the 3/8” porcelain tile at last. (the whole assembly may not be 1-1/8” but close enough for me) I know that hardie manuf. won’t warranty their product if it applies on the concrete slab directly. I also know that many people in the forum points out that I should not do it either. Here are my questions: 1) If I don’t care about the factory warrant, do you guys think that it is OK to use hardie backer board over concrete? If not, why? 2) How do I secure the board to the slab, would thinset be enough, or do I need to put additional screws to the slab? 3) What screw should I use? 4) What is the better way to raise the floor other than using backer board? I try not to use self-leveling concrete or similar method since it is too difficult for me to do. Do you guys have other recommendation? Thanks a lot for your help |
I think the best way to raise the floor is to install a mortar bed but if you want to install the backer board make sure you use a notched trowel and thin set mortar to bond the cement board directly to the concrete. No screws needed.
I am doing almost same project right now.
I am working on 1/2 bathroom on the 1st floor. Its about 27 sq ft. I removed old tiles already with hammer and pry-bar. I damaged mud bed under the tiles though, so I had to remove it too. So now I guess I have to chose between SLC or Mortar Bed since I had Total Fiasco with CBU over Concrete Slab. Its like glueing two pieces of metal with Crazy Glue. |
| All times are GMT -4. The time now is 05:13 AM. |
