Cement Backer Board - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 01:23 PM   #16
I have decided to cut a straight edge and put in a 1/4 piece were the stair was so that the bottom is even, then will put 1/2 exterior grade plywood over the particle board, make sure all is level and then put 1/4 backer board over that. Then put my 12 x 12 tiles down. I am hoping i will have enough room. I did notice a saw that cuts sideways in the hardware store (looks like a trowel) anyone have any experience with one of these?
wadeseward is offline   Reply With Quote
Old 09-10-2010, 11:34 AM   #17
floor_whore
Send a message via Yahoo to Aaroncarpet
I believe you are talking about a dovetail/jamb saw...is it fine toothed...I use one to undercut dooor jambs so the new material can slide under them.
A hundred yards a day (residential), keeps the bill collectors away....
Aaroncarpet is offline   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Cement backer board - which to use? manhattan Building & Construction 3 09-14-2009 03:57 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
