Caulking Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2008, 10:07 AM   #1
caulking tile
I'm assisting someone install a shower, it's ceramic tile and I'm wondering if he can caulk the floor instead of grouting it. It's been water proofed with a membrane, just curious if that can be done.
rdmccaw is offline   Reply With Quote
Old 09-22-2008, 10:34 AM   #2
RippySkippy's Avatar
can it be done...SURE! Should it be done, NO.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-22-2008, 10:34 AM   #3
what can happen if it's done?
Old 09-22-2008, 10:47 AM   #4
It's just not the right material for the job. It won't make the floor come up, and yes it will probably look ok for a while...but it should be grouted for durability.
LMASD
Old 09-22-2008, 11:38 AM   #5
Registered User
Termite's Avatar
Grouting is not difficult. All you need is a big sponge, a grout float, and a 5 gallon bucket of water.
Caulking instead of grouting is not an acceptible practice, and will look like hell within weeks. It'll kill whatever value the tile might have added to the home as well.
Old 09-22-2008, 11:48 AM   #6
Is there an addative that you can put in with the grout to make it more waterproof?
Old 09-22-2008, 12:45 PM   #7
All right KC, why not get to the point?!?!?!?
About the best you can do is seal the area. Tile and grout is not intended to be water proof, resistant at best. When you mix the grout you can put a latex additive which makes the grout less susceptible to cracking and stain resistant. But not water proof
LMASD
Old 09-22-2008, 01:32 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The Tile Council of North America recommends that "All changes in plane be caulked". That's the way it has been for a long time now.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tub & Tile Caulking powrus General DIY Discussions 3 11-24-2006 04:15 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
