-   -   caulking around tub (http://www.diychatroom.com/f5/caulking-around-tub-128443/)
Judy D 01-01-2012 08:45 PM
caulking around tub
Hi, I have a fiberglass tub and want to recaulk between the tub and floor, do I have to remove all the old caulk which is very hard to do. I am using a good putty knife and some of it is impossible to get off. If I do need to remove it all, what is the best way to do it? Thanks!
JazMan 01-01-2012 09:47 PM
Hi Judy,
It won't look so good if you don't remove the old. However as you know, it's not easy and there's a chance you might cause damage to the tub if not careful.
A heat gun, hair dryer will help. If the old is silicone, they make removers. "Dap" brand is one I've used. Wooden "putty" knives don't damage.
Jaz
joecaption 01-01-2012 09:52 PM
What"s on the floor now? If it's tile then use a single edged razor knife.
new Silicone will not stick to old caulking.
