Cast Iron Radiators On Laminate Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 08:09 PM   #1
cast iron radiators on laminate floor
I have several radiators that will be re-installed in a couple rooms. They were removed during remodel. New laminate flooring was installed on entire floor. I know that they cannot sit on the laminate as they weigh roughly 400 lbs each. I was thinking that I could use a small hole saw and drill thru laminate where each of the four feet on a radiator sit so that nothing is b bearing on laminate. I have covers for the radiators that would hide the feet. Any thoughts?
klally is offline   Reply With Quote
Can I use a cast iron sink with stainless steel appliances stjames1 Interior Decorating 0 06-25-2010 07:49 PM
Hi & Low Limit setting - Oil boiler, forced HW - Cast Iron radiators Scuba_Dave HVAC 40 01-10-2010 01:39 PM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 06:49 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 04:06 PM
