Cast Iron Clawfoot Tub Weight Concerns - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 05:13 PM   #1
Rewards Points: 49
Cast Iron Clawfoot Tub weight concerns
I want to put a cast iron tub in the second floor of a 1903 Victorian. The joists are 2x10, 16oc. I think they span 16 feet but I am sistering them to span the length of the bathroom which is 5 feet. This will make for 5 2x10's spanning 5 feet.
A clawfoot weighs about 300, plus a human and water, for a total of upwards of 700 pounds. Will the joists be able to carry the load?
jrdamien is offline   Reply With Quote
Old 04-16-2009, 05:17 PM   #2
Specifically,
http://www.google.com/search?client=...UTF-8&oe=UTF-8
More generally,
http://www.amazon.com/Basic-Lumber-E.../dp/1572180420
Old 04-16-2009, 05:20 PM   #3
Rewards Points: 49
Kind of defeats the purpose of an advice forum, no?
Old 04-16-2009, 05:22 PM   #4
My bad.
Old 04-16-2009, 05:23 PM   #5
Rewards Points: 49
I was only teasing.
Old 04-16-2009, 05:24 PM   #6
Rewards Points: 49
My question isn't only about the load capacity of said joists, but a more nuanced interest in whether the rim upon which they will be resting might be impacted as well as surrounding structural components I may not even know about or know enough about to consider.
Old 04-16-2009, 05:30 PM   #7
Check for excessive structural deflection with the weight of one or two people in place of the tub. Scale up to the tub weight for whatever deflection you measure. The scaled-up value should probably be less than 1/4".
Old 04-16-2009, 07:40 PM   #8
Registered User
Rewards Points: 5,240
I'm still trying to figure how to sister a 16' span down to 5', without closer bearing. Could anyone explain that to me? Be safe, GBAR
Old 04-17-2009, 08:03 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Sounds like he only sistered four of the 16' joists for a width of 5 feet.
Old 04-17-2009, 05:01 PM   #10
Registered User
If the span is 16', by looking at the ceiling of the room size downstairs, the bath 5' lands somewhere in that span.
To just add a sister joist next to a longer joist, you're just adding more weight.
The span has not changed any, unless you add a closer bearing point.
The good news is the old joists are a full 2"x10", real measurement. With today's joist that size, is rated at 40# live load, 10# dead load times 16' = 800# per square foot. Minus any walls, other fixtures, or adjoining room weight (dressers, beds, etc.)
Be safe, GBAR
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General DIY Discussions 5 03-04-2009 06:24 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 01:07 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
