Carpeting VS Carpet Squares - Flooring - DIY Chatroom Home Improvement Forum
Old 12-13-2007, 08:16 AM   #1
Question
Carpeting VS carpet squares
I have a class A motor home and would like to replace the carpet myself. The problem comes , when I need to carpet the engine cover. It has rounded curves. It was also glued. I could use carpet squares on the main floor but what to do with the engine cover. Any ideas? Someone said you have to steam the regular carpet to work. Can you glue carpet squares?
captsam58 is offline   Reply With Quote
Old 12-13-2007, 12:11 PM   #2
The carpet squares may not conture to the shape of the engine cover.
redline is offline   Reply With Quote
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 04:21 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
