Carpeting For Slab On Grade Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2008, 12:01 PM   #1
abc
carpeting for slab on grade floor
I have a slab on grade floor. Asbestos tile has been removed, leaving ugly black material. We may have some minor water infiltration (infrequent) through the base of an outside wall or possibly up through the concrete. We plan to install carpeting. We are also planning to repair the outer wall in the spring, but need to finish the interior now. Would it be best to install a subfloor over the concrete before the carpeting, or should we just use a moisture resistant padding directly on the slab? Additional insulating value from sub-floor would not be a bad thing for this room. Another alternative would be to scrape the black junk off the concrete and paint/seal the concrete before installing a subfloor or direct carpeting. Thoughts?
abc is offline   Reply With Quote
Old 01-18-2008, 12:31 PM   #2
Tile pro
All Tiles's Avatar
I would recommend FIRST fixing where the problem began, hence your outside wall (even a temp solution is fine until the spring). Then, moving into your home,
-scrape and treat moldy areas
-add min. 1/4" sub flooring, so your carpet sits nice and firm
-Add your padding and carpet
All Tiles is offline   Reply With Quote
Old 01-18-2008, 03:41 PM   #3
Rewards Points: 150
1/4 inch over concrete?
I wouldnt do that.
You can put carpet and pad right on concrete. Just fix the water issue first
mike costello is offline   Reply With Quote
Old 01-18-2008, 04:18 PM   #4
Tile pro
All Tiles's Avatar
Sorry, my bad, that's 1/2".
It's a basement, the moisture that basement's retain are unbelievable, i wouldn't recommend NOT using plywood. But then again, that me.
We use to have carpet/pad right on cement floors in our basement, and once we added and extra 1/2" plywood with polythene ( it's an orange membrane)to the padding, it made a huge difference on how cold our floors would get in the winter, not to mention the humidity went away.
Then again maybe where you live -25 degrees Celsius is not very common and straight padding on your cement floors works just fine. It is again a much cheaper solution.
Old 01-18-2008, 09:57 PM   #5
abc
We've got a temporary fix on the outer wall until we can do permanent work (and window work) in the spring. The room is on grade, not a below-grade basement. Is there any advantage to adding a subfloor? What material and thickness would your recommend? Any benefit toadding a layer of plastic or use the material with pe spacers on the bottom? Should we just go with moisture resistant padding?
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 11:58 PM
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 04:43 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
