Old 04-23-2009, 02:03 AM   #1
carpeting
I want to do carpet to my new added room. Can I do skirtboard before the carpeting. or do I need to do skirtboard after the carpet
mpj111 is offline   Reply With Quote
Old 04-23-2009, 08:05 AM   #2
Pro Flooring Installer
rusty baker's Avatar
carpeting
Either way is fine if you are putting down a pad. If glue down, it is easier if the carpet goes first.
Old 04-23-2009, 09:16 AM   #3
carpeting
If skirtboard and baseboard are the same thing you can go either way. Personally would want to do the skirtboard/baseboard before carpet. You can raise the skirtboard/baseboard a 1/2" which allows the carpet installer to tuck the carpet under for a nice neat appearance and this makes painting easier in the future because you can slide a thin piece of plastic between the skirtboard/baseboard and carpet. If you decide to do the skirtboard/baseboard after the carpet be sure to ask the installer to compensate for this by moving the tack strips an extra 1/2" to 5/8" inch away from the wall. The problem if you do not account for the extra 1/2" it will make replacing the carpet in the future much more difficult because the tack strips will be under or too close to the skirtboard/baseboard.
Rege
RegeSullivan is offline   Reply With Quote
Old 04-23-2009, 07:04 PM   #4
carpeting
Thanks for the reply. I have done part of the skateboard before I post the question. Now I got the idea, I can do the rest as well.
Old 04-24-2009, 06:30 AM   #5
carpeting
Good luck with the carpeting project.
Dana11 is offline   Reply With Quote
Old 04-27-2009, 11:11 PM   #6
carpeting
I have to get your idea befor I started my carpeting.
I have two new rooms , with wooden particle board.
4.3mx3m
and
4.3mx2.5m.
Carpets are available 69$ per meter in 3.6m wide.( NewZealand dollers)
Under lays ae 25$ per meter.
Nailed strips are cost 1.88$ /m
WEhen I totaled it cost me carpets 602$+ underlay 215$ and nailed strips anothre 50$.
total 867$.
Is there any other cost on top of this as a DIY project.
One shop gave me a quotation for 1100$ to 1200$ to do my carpeting.
If I do it as DIY I can save 330$ acording to above figures. Do you think is it worth to do it as DIY project. or better to higher a person to do it for 1200$.
much appreciate your comments.
removing carpeting from concrete BECK5791 General Discussion 1 04-07-2009 05:42 PM
It's true. Size matters. - Carpeting Question kcrossley2 Flooring 4 11-19-2008 12:32 PM
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 04:43 PM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 09:58 AM
laminate vs. carpeting crittall@capital.net Flooring 4 04-05-2008 04:17 PM
