Carpet, What To Look For? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2013, 07:55 PM   #1
Rewards Points: 640
carpet, what to look for?
I've never purchased carpet before.. so I'm not too sure what to look for..
I don't want builder grade, I want higher quality.. I've seen some stuff talking about face weight per square yard with low end being like 24oz and not sure where the high end is at? Any recommendations for this?
What makes a good padding?
What makes a good carpet?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 12-09-2013, 09:35 AM   #2
Rewards Points: 13,270
http://www.georgiacarpet.com/pages/s...ng-carpet.html
Old 12-09-2013, 10:39 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Without knowing what kind of carpet you like, plush, berber, etc, it is hard to tell you carpet weights and pad specifics. Different types of carpet, need different densities and thicknesses of pad, too.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-09-2013, 11:39 AM   #4
747
registered
747's Avatar
Rewards Points: 534
Just go to a real carpet store. Tell them what your budget is. Then say i want to upgrade the pad. This is what i did. My carpet is really cushy. I basically told them. I don't want the cheapest. But i don't want the most expensive. Something inbetween which will holdup. They will need to come out and measure. Finally i pad for removal of old carpet. Also paid for them to move furniture. Don't go with those dick's at lowes. REAL CARPET STORE.
747 is offline   Reply With Quote
Old 12-17-2013, 08:31 AM   #5
Rewards Points: 101
Post
When you go to bend the carpet and you see the backing it is cheep carpet. What you want to see is NO backing. This will tell you that this carpet is high quality. It will cost more but it will last for a long time.
When you walk on it you will know you have quality carpet.
nhoj is offline   Reply With Quote
Old 12-17-2013, 09:24 AM   #6
Rewards Points: 42
Not necessarily true. Some carpets, like berbers, you will see the backing when you bend it over, no matter the quality. As a general rule, face weight will tell you the quality of the carpet. 18oz is about the cheapest and 60oz is the best you will find in most carpet stores.
As far as pad goes, the range is 4lb to 8lb, 1/4" to 1/2". Different thicknesses and different weights are suggested for various carpets. A good pad will make even a cheap carpet feel better and last longer.
Old 12-17-2013, 09:37 AM   #7
Rewards Points: 101
I agree with you on the weight of the carpet, buy quality.
Couple carpet questions ponch37300 Flooring 8 09-28-2012 03:30 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
