Old 07-28-2006, 04:22 PM   #1
Carpet Water Damage
If someone had some minor flooding - and I know a lot of people who just did - Is it enough to use a shop vac to remove all possible water, and use a fan ?
All my research states to pull up the carpeting to dry the padding properly (or replace the padding).
Eight inches of rain !!
tribe_fan is offline   Reply With Quote
Old 07-28-2006, 04:42 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Carpet Water Damage
Wetvac will not be enough, you need good air circulation between the layers to properly dry out, not doing so will be asking for mold to grow.
I may not understand what your asking here.
Ron The Plumber is offline   Reply With Quote
Old 07-29-2006, 12:00 PM   #3
Carpet Water Damage
You got it Ron -
They pulled up the rug, and are replacing the padding.
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
