Carpet Underlay To Reduce Noise - Flooring - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 10:35 AM   #1
Carpet underlay to reduce noise
Hello all..hope you could help me with the following.
Current setup for the room upstairs is hardwood with carpet above. We'd like to put something under the carpet to reduce the noise (could hear the person sleeping in that room snore and sometimes there is banging from their cane). I know we can't eliminate all sounds but we'd like to reduce. Any suggestions as to what we could put under the carpet?
Also, I recently went to a carpet store and explained the situation and they suggested a product called Super Dura. Below are the specifications. Could you please comment? Thx.
Product details:
Made with post consumer recycled tire rubber (min. 85% content) bonded with synthetic latex
Super Dura®
Backing: Poly
Thickness mm (in.): 10 (3/8″)
‘‘R’’ value: .88
Mass oz / sy: 106
Roll Weight / lbs: 66
Density lbs / cu. ft.: 22
Compression Force
Deflection lbs / sq. in.
@ 25% min 2
@ 25% max 5
@ 65% min 50
silvercity is offline   Reply With Quote
Old 04-19-2013, 02:19 PM   #2
Anyone
Old 04-19-2013, 02:23 PM   #3
Floor Installer
sam floor's Avatar
Rewards Points: 154
Rubber pad tends to get hard and disintegrate over time.
sam floor is offline   Reply With Quote
Will the noise reduce if installiing drywall on a glassless window? baby327nd Windows and Doors 2 03-21-2011 08:55 PM
Would a drop ceiling reduce percussive walking noise from neibor above? fredonian Building & Construction 8 05-19-2009 03:23 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
