Carpet Under A Floating Floor... - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 06:18 PM   #1
Carpet under a floating floor...
I was wondering if I can use the sisal rug (extremely low Nap) and a vapor over it as the underlay for a bebop floating floor? Inlaid out some of the planks to look at color and it is lying flat and comfortable to walk on. It is a "click" floor
Mr Bike is offline   Reply With Quote
Old 04-21-2013, 06:58 PM   #2
Rewards Points: 12,876
Ok I give up what's a bebop floating floor?
Unless you use exactly what the manufacture states there is no warrenty.
Old 04-22-2013, 05:49 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
No manufacturer will warranty this. I have seen a relative of mine install an 8mm laminate over properly glued down commercial carpet with no ill effects in the past 8 years. That was an extremely low tight nap and it was fully adhered though.
Darkling Designs
poppameth is offline   Reply With Quote
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 03:38 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
