Old 12-10-2010, 05:26 PM   #1
Carpet transition to lower surface
In my basement I'll be installing carpet over a 7/16" pad, 3/4" plywood, 1-1/2" rigid foam, and dimpled membrane. What is a graceful way to make the transition between the carpeted area and much lower porcelain 3/16" tile over Ditra? I'm not performing the carpet installation, but I want to make sure I don't present a problem for the installers. The height differential could be as much as 2".
benjamincall is offline   Reply With Quote
Old 12-10-2010, 06:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Why are you putting plywood on concrete? That's a recipe for failure and not needed.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-10-2010, 06:42 PM   #3
The plywood is going over xps foam and Delta-FL dimpled membrane.
Old 12-10-2010, 07:49 PM   #4
Well, I wish you luck.
Old 12-16-2010, 11:52 AM   #5
Any ideas on how to achieve a graceful 2" transition from carpet down to porcelain tile?
Old 01-14-2011, 11:48 AM   #6
Here are my numbers again:
1/8" thinset and Ditra + 1/8" thinset between Ditra and tile + 1/4" porcelain tile = 1/2" finished floor height.
5/16" Delta-FL + 1" XPS Foam + 19/32" AdvanTech + 7/16" pad + 1/2" Carpet = 2-27/32"
What should I do in the doorways to the bathroom and at the entryway where the carpet meets the tile? Should I do away with the XPS foam and put the AdvanTech right down on the Delta-FL? That would buy me another inch. A difference of 1-3/8" is still pretty big.
Old 01-14-2011, 03:02 PM   #7
woodman58's Avatar
Why are you putting all this under the pad and carpet? In the mid-west we just put pad and carpet only.
woodman58 is offline   Reply With Quote
Old 01-14-2011, 03:20 PM   #8
The membrane is there for water vapor and for small amounts of water inflitration. If you don't have insulation under your slab, adding a layer of closed cell foam insulation can prevent cold floors. The floor sheathing provides a level surface for the carpet and prevents compression of the foam. I may go without the XPS insulation if I can't find a good way to reduce the height.
Old 01-17-2011, 08:41 PM   #9
I was thinking perhaps I could use some Wedi board to bring up the level of the tile, but I have no experience with Wedi.
Someone on a different forum suggested that I create a mud bed, but an area as large as the one I'll be tiling would present a big challenge for me.
carpet to laminate transition 8roty Flooring 3 11-08-2010 07:41 AM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
engineered to carpet transition stallinc Flooring 9 01-28-2008 11:07 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
