Carpet To Tile Joining - Flooring - DIY Chatroom Home Improvement Forum
Old 07-10-2007, 04:17 PM   #1
carpet to tile joining
Goodmorning I am new here so I hope I do this right.
Have just had ceramic tiles installed in the front doorway of the lounge room (entrance) by a diy weekend handyman-for-hire; but he didn't finish off the join with the carpet - said he couldn't do that and I should get 'the carpet people' in to do it. Please help me finish this off. He has put an aluminium angled piece at the edge of the tiles. The tiles are actually slightly higher than the carpet (just a smidgen) I bought some metal edging with a 'gutter' to hold a soft plastic cover that goes over both tiles and carpet (is this called a saddle????) but because I had to nail it in, it then seated too low to take the plastic cover. Should I try to lift this edging and put wooden strips in to lift it??? Can anyone help please? I am recently widowed and need to be able to do these things for myself now. Dozey
dozey is offline   Reply With Quote
Old 07-10-2007, 05:28 PM   #2
Rewards Points: 150
Maybe a picture would help if you can post one... IMHO, if the carpet was already in place, I would expect the tile setter (DIY handy man or not) to put in the proper transition. The metal edging he put on could have been a transition piece if placed properly...
slakker is offline   Reply With Quote
Old 07-11-2007, 07:29 AM   #3
RippySkippy's Avatar
Slakker is right...he should of finished the job. Can you remove and shim under the edging? I know it would be a pain...but it wouldn't be that though to do. Get a wide flat pry bar and it would help to pop it up with out damage. Depending on the height, masonite would work...you might consider re-installing with screws, easier to snug up and would hold better.
RippySkippy is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
